Video encoding for iPhone
B-Line
Jul 6, 2007
11
I have some short films that are encoded in:
Mpeg-4 Video, ACC
Dimensions 624x368
- Am I using dimensions that are to big?
both films are 15-20 minutes and are 150mg-200mg respectively
B
jjvaldez
Jul 3, 2007
2,615
35
Salinas, Ca
needs to be : 480-by-320-pixel
and only accepts :
Video formats supported: H.264 video, up to 1.5 Mbps, 640 by 480 pixels, 30 frames per second, Low-Complexity version of the H.264 Baseline Profile with AAC-LC audio up to 160 Kbps, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats; H.264 video, up to 768 Kbps, 320 by 240 pixels, 30 frames per second, Baseline Profile up to Level 1.3 with AAC-LC audio up to 160 Kbps, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats; MPEG-4 video, up to 2.5 Mbps, 640 by 480 pixels, 30 frames per second, Simple Profile with AAC-LC audio up to 160 Kbps, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats.
this is on the Apple website
hope that it works...
Doc Holiday
Jul 10, 2007
37
Las Vegas
My Video Settings
iPhone can play 640x480 video files. I have converted DVD movies to .MP4 with H.264 codec at 640x480 at 1000kb bit rate 29.97fps and they look great! File sizes range from 300-400MB per hour of video. I like encoding to 640x480 because my videos play full screen without black bars on left or right sides, but if file size is an issue encode 480x320 at a lower bitrate.
Nuggets
Jul 7, 2007
What program did you use? I'm having a hell of a time finding something that will let me convert DVD to 640x480 like you said. Most tools I tried are dumbed down and don't really tell me what the output is going to be.
Doc Holiday
Jul 10, 2007
37
Las Vegas
I know aren't they, pretty frustrating huh? Tell me what you're using and what you're converting (dvd, recorded tv?) I use a bunch of different tools depending on what I need to convert. I haven't found a program that does it all, not yet that is :laugh2:
rebelace
May 30, 2007
193
Beaumont,Texas
www.thechadburge.com
No way I could encode my beautiful widescreen movies to 640x480 that makes me cringe I just use there native aspect ratio and encode them for iPhone using visual hub because all my movies I like are already on my laptop anyway.
IPhone_Chica
Jun 14, 2007
77
Right now I use Cladvd net and Super Converter. It seems to be working well. Both are free programs. I love Cladvd net better than DVD Decrypter because it selects the movie file for u. When it's done doin its thing u are left with only one file. I use Super over Videora cause Videora kept jackin up my iTunes even when I unclick the sync with iTunes option. Hopes this helps.
Doc Holiday
Jul 10, 2007
37
Las Vegas
By all means keeps your widescreen videos widescreen. I just meant fitting them to 640x480 (letterboxed).
Thanks for mentioning Visual Hub! What a great program I just wish I had it sooner! I love the cropping feature w/preview and that it converts Windows Vista DVR-MS recorded show files!
Nuggets
Jul 7, 2007
I just want a way to take me from DVD to iPhone at 640x480. If I have to decrypt the DVD myself, thats fine too but if something could do this simply in one shot, that would be better.
bjgiPhone
Jul 15, 2007
Have you tried cucusoft?
Nuggets, Have you tried cucusoft?
I've been using it for a while for custom output without issues. I'm pleased with the product. (http://www.thevideolife.com/iphone-convert-dvd.html)
