Video format for iPhone
FREDG
Jun 12, 2007
29
what video format can i use with my iPhone i converted some videos to mp4 but when i go to drag and drop into iTunes it don't work and when i click to play it it says there is a bad public movie atom or something like that. anyone knows wat to do?
RyanFavre
Mar 16, 2007
250
Milwaukee
I have a question about this too. I have most of my videos in as .wmv files and i know those won't work, but i had one video that is in .mov format and i tried to sync it to my iPhone and i got a message that said "this video will not play on your iPhone". Kinda blew me away that a quicktime video won't play on the iPhone.
So what formats is the iPhone taking exactly?
FREDG
Jun 12, 2007
29
hey i just found out how to do it your going to have to convert the videos to mp4 but it has to be mp4 for ipod i tired the other ones like the regular mp4 abd it didn't work
rcossy1023
22
How do I convert to mp4 for ipod...?
godspropy
Jun 13, 2007
I imported some avi (divx) files into iMovie. It was going to take forever to actually export the new file according to the specs below. So, I just grabbed the .mov files from ~/Media directory under the project and synced it. And, it worked!
http://www.apple.com/iphone/specs.html
Video formats supported: H.264 video, up to 1.5 Mbps, 640 by 480 pixels, 30 frames per second, Low-Complexity version of the H.264 Baseline Profile with AAC-LC audio up to 160 Kbps, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats; H.264 video, up to 768 Kbps, 320 by 240 pixels, 30 frames per second, Baseline Profile up to Level 1.3 with AAC-LC audio up to 160 Kbps, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats; MPEG-4 video, up to 2.5 Mbps, 640 by 480 pixels, 30 frames per second, Simple Profile with AAC-LC audio up to 160 Kbps, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats
shift_2kmaxima
Jun 9, 2007
the best thing to do is download iSQUINT
its for free, just google it
thats only for MACs tho
and when you open it, it'll ask you to add a video, you add it
and then there is check mark you can put
"convert for TV"
"convert for iPOD"
you click on "convert for iPOD"
and also it asks u for quality
and there is a check mark you put for "H.264 encoding"
after that you click start, wait couple min and your video is ready,
I already have two music videos on my ipod and they're working just fine,
at first when i converted one of the videos without checking "h.264 encoding"
i didn't have picture but i had audio, then i figured out the problem
i hope it helps
later
rcossy1023
22
"convert for TV"
"convert for iPOD"
i hope it helps
later
I got stupid windows....got anything for that?
shift_2kmaxima
Jun 9, 2007
nope...iam sure there is something out there
just google it, thats how i got isquint
you need converter for an iPOD
