Video: Incipio Light Feather Case for iPhone 4
chris
Administrator
Administrator
Jun 10, 2006
11,813
1,779
Long Island, NY
I like this case. I have the same case for my Zune HD. You'll note the issue with the corner not fitting properly. This was caused by me, who thought it was a good idea to pull the case off by pulling the corner. I opened up the purple case for my wife's iPhone 4 and it fit perfectly. I should note that it won't create a lip that covers the edges of the display, so you cannot lay the iPhone 4 flat on any surfaces.
Bennyboy
Jul 21, 2010
14,017
1,756
PA
I love incipio, cool case, I had the same problem you did with the invisible shield edges so I took them off to fit the incase snap. Couldn't stand that lip. They booth look alike a lot.
I'll stick with the silicrylic for now.
Njshoremom4gurlz
Sep 13, 2011
536
84
Using it now but will be lifeproofed for
This summer lol!
