VIdeo plays fine, but audio is a different story
svtguy08
Aug 4, 2007
CA
Hello all. I have used Videora iPhone Converter to convert a movie that is in .avi format. It converted, loaded into iTunes, and sync'd to the iPhone successfuly. BUT when I play it back on the iPhone the video is crisp and clear BUT the audio is scrambled and cannot be heard or understood. I have tried every different profile in Videora along with different bit rates, freq's, channels and NOTHING worked. Any Suggestions?
I have the same problem with Aimersoft Video to iPhone Converter BUT when I convert and ISO with HandBrake everything is perfect.
Also can i convert the .avi movie file into an ISO so I can use HandBrake instead?
Thanks for the help!
edit: I also uninstalled and reinstalled and that also didn't work!
skiz420
Jul 28, 2007
371
Boston
as far as doing avi to iso... just type in "avi to iso" in google... there are a bunch of softwares that will allow you to do that... a lot are shareware...
