Video recording is finally here (beta)
coolie
Sep 18, 2007
131
Yes I saw. I really like it. It takes really good quality. Can't wait to be able to save the videos and sound and unlimited recording.
psylichon
Oct 31, 2007
16,591
751
40
Philly
Nice. It's these proofs of concept that really excite me about "hacker apps"
I
iphone
Guest
İ really appreciate what the hackers are doing. They found İradio now this, a Video app. Wow
İ really want to watch Tv on my İphone and i cannot wait for this app. Hope someone finds out how.
I
iphone
Guest
By the way i installed the video app on my windows xp. Can some one tell me how to put it in my iPhone and activate it pls?
Tinman
4,334
183
Aridzona
Wow, I checked it out and was impressed with the quality of the video. Can't wait till it allows saving of the video file.
Mike
Hi-Phone
Jul 5, 2007
104
Mike
How do you install this great sample app? Thank you!
Tinman
4,334
183
Aridzona
You first have to download it from the author's blog, which requires registration.
You then unzip it and copy it ("it" being Drunknbass.app) to your /Applications folder, give it execute permissions, restart the springboard and it'll be ready to go.
Mike
Nov 28, 2007
2mp quality @ 10fps. Awesome! Drunknbass, keep up this excellent work, you rock!
imapfsr
Oct 2, 2007
Victoria, B.C. Canada
hey all,
does anyone know if this only works with Mac. I downloaded it on Vista. zipped and copied and the icon is there but I just get a black screen for 5 secs then goes back to main screen? Any ideas.
enigmanic
Jun 27, 2007
513
hey all,
The app should work fine on Windows. After you copy the application, you need to set permissions to 755 for it to work.
enigmanic
Jun 27, 2007
513
Thanks for the reply, I forgot to mention I did get an error when I unzipped the file. Not sure why.
Not sure why you're getting an error when unzipping. Try downloading the file from MMI (you'll need an account):
http://www.modmyi.com/forums/downloads.php?do=file&id=1670
Once extracted, you'll need to chmod the file "Drunknbass" to 0755.
So do you need to have it jailbroken for this app or can you do it with a un-broken phone ?
Yes, you need to have a jailbroken phone.
mrgrumble
Oct 26, 2007
117
Strong Island, NY
ok so how do i downgrade my phone to 1.1.1. after I already have 1.1.2. installed i guess i'll keep my phone at 1.1.1. i miss my 3rd party apps. Does jailbreakme.com still work for phones using 1.1.1. or did they block that out too?
xcissexc
Aug 9, 2007
501
Nov 28, 2007
hey all,
I'm using Vista with WinSCP, no problem here. You need to reset the permissions of the drunknbass.app folder and the files inside that folder to 0755. Assuming your using WinSCP and have copied the drunknbass.app folder to the Application directory on the iPhone, right click on the drunknbass.app folder and select "Properties." Then reset the permissions to 0755. Do the same with the 2 files inside the drunknbass.app folder (Info.plist & Drunknbass). Then reset the springboard or reboot the iPhone and you should be good to go.
WOW! All he has to do now is extend the time with a variable, wrap it in a skin with start and stop buttons and configure a save function. Yep, that's all.. (much easier for him than the rest of us I suspect, but Tinman could probably do it...) :laugh2:
Very cool app! Kudos! :cool:
