video wallpaper is here!
xcissexc
Aug 9, 2007
501
has anyone tried the new vWallpaper. right now its only a test and it only plays 1 video but its got potential. the only problem i noticed with it is that when you are on your home screen the screen doesn't trun off, i guess it acts like something is being done by the user so the auto-lock doesn't kick in. im going to play around with it to see if i can replace its video with a custom video of mine. i will report back.
24trepid
Jan 13, 2008
502
Just installed it, AWESOME........
Here's the source http://i.danstaface.net
It's called vWallpaper.
The only one on it right now, is an exploding fireball behind your icons.
SO COOL ........:cool:
Bone
Feb 11, 2008
1,214
this is soo sweet! I can't wait till there are more choices or you can use your own video. Anyways I duno if I'm gone be able to use it until after some of the bugs are worked out because when I enable it on my phone and then for enstance pull up safari to do a little EIC browsing my touch screen won't work. Any suggestions?
24trepid
Jan 13, 2008
502
Yeah, it's a little buggy. Has great potential, though.
xcissexc
Aug 9, 2007
501
ok so i found where the movie is located. applications/vWallpaper.app/library/skrew/videos and the movie is fire.mov. i deleted it and replaced it with my own fire.mov but its still the original fireball that shows up. i double and tripple checked to make sure that it was my movie that i uploaded. i did a respring to the springboard and i even did a hard restart and still the original movie, that i deleted, plays. weird. guess il do a little more snooping around. if anyone knows what the solution might be that would be great and if i find the solution will let you guys know
xcissexc
Aug 9, 2007
501
ya i had that problem too you just need to do a hard reset and everything works perfect again
jptolife
Jul 15, 2007
645
New York City
This little app is great and everything has worked well for me. Can't wait for other animations!
xcissexc
Aug 9, 2007
501
ok i figured out how to change the video. you need to replace fire.mov with your own fire.mov in both applications/vWallpaper.app/library/skrew/videos/ and library/skrew/videos/ you just need to upload the same video in both locations and make sure that it is called fire.mov all lowercase
H
Hayesimus
Guest
wow this is so cool. i'll have to check it out. Can someone make a quick video and post it on youtube or something and show us? My only concern is that it will reduce battery life.
xcissexc
Aug 9, 2007
501
i was also concered about battery life but it doesn't seem bad so far. the video only plays on the home screen and when im using my phone im not on the home screen that much. il make a video on youtube now il post the link here when done.
H
Hayesimus
Guest
see thats what i was curious about. Is it ALWAYS running in the background? Does it show on the lock screen?
xcissexc
Aug 9, 2007
501
its not on the lock screen and so far it doesn't seem to run in the back ground. my battery doesn't seem to have drained any faster than ususal since i have installed.
im having trouble uploading a video to youtube so if someone else could do that for hayes and other people that would be great
H
Hayesimus
Guest
yes. i'd appreciate it. I'm wanting to see what it looks like before i install it. I may wait til they expand on the idea
Bone
Feb 11, 2008
1,214
also. It would be nice if the icon it came with wasn't the same as iapp a days wallpaper app icon.
H
Hayesimus
Guest
i usually make my own icons anyway.
Jul 6, 2007
1,832
26
Marietta, GA
about.me
hey i just now downloaded this app and it came with 2 different movies for the wallpaper, one is the fireball one you described and the other is the one of a drop of water falling into a puddle and then it shows the ripple effect. both are really cool. and i noticed at the bottom of the application settings screen it has a todo list including a way to share videos online. i think that will be awesome.
EDIT: the only thing i hate about this is if you have it enabled and are listening to music, then go to the home screen, it stops the music =[
Jul 6, 2007
1,832
26
Marietta, GA
about.me
hey guys i went to the developers website, and they already made their own video and it demonstrates the video i was describing and one that isn't available to us yet.
H
Hayesimus
Guest
sweet. yes if you can put your own vids back there it would be amazing
GADeputy
Jan 21, 2008
381
Georgia, USA
hey i just now downloaded this app and it came with 2 different movies for the wallpaper, one is the fireball one you described and the other is the one of a drop of water falling into a puddle and then it shows the ripple effect. both are really cool. =[
That's strange, I just installed it and mine only came with the fireball movie. Anyone know where I can get the water drop from?
24trepid
Jan 13, 2008
502
Refresh sources, a new update for vWallpaper is out.
It's version 0.3
Has fire video and water drip video now.
