Videos won't sync
Rickster
Aug 28, 2011
20
Since the latest update to iTunes (version 12-the new red icon) videos that I had stored on my pc that I moved back and forth from PC to iPad now won't go onto the iPad any more.
What have Apple done?
Anyone else experiencing problems?
Ps they won't go onto my iPhone 5 either, that's why I suspect iTunes and not the devices.
Rick
Rickster
Aug 28, 2011
20
Make sure your computer is authorized in iTunes. The update may have removed it from the authorized list. Here are directions:
http://support.apple.com/kb/ht1420
Thanks for the replies, I uninstalled iTunes then reinstalled which seems to have sorted it out.
Can only think that the update broke something.
Rick
28,365
5,507
Rick
Did you try authorizing it first? They occasionally just need to be reauthorized following updates.
Rickster
Aug 28, 2011
20
All I did was un/re install iTunes.
