VLC videos sometimes has no sound
Got_famous06
Jan 26, 2014
49
I put a video on my iPad and im using VLC, the video sound works on my PC, but trying to play it on VLC on the iPad, there is no sound. im at work so i cant re-sync the video and it sucks that I cant watch it now...is there any fix i can do on the iPad side?
5,580
Select "Reset preferences" in the VLC app settings.
Got_famous06
Jan 26, 2014
49
I don't see that in the VLC app setting or going into the settings app and going down to VLC and looking in those settings.
5,580
Just installed it and that option does seem to be missing now. Reinstalling it should fix it. I haven't used VLC for a long time. I use Air Video HD now. It makes getting content moved over to my iPhone and iPad for offline usage much easier. I don't have to be home to do so. It can be done remotely. You can just stream it if you're not offline. It does live conversion, so the format doesn't matter. Check it out if you continue to have problems with VLC.
CK Santos
Aug 17, 2015
Try Nplayer, it's not free tho but great app :)
