Voice Control starts automatically, constantly
BabyWife
Aug 26, 2012
I have been having issues with the Voice Control starting all by itself. It apparently tried to FaceTime someone last night while I was asleep...phone was on the bedside table. I can tap cancel, move on to another task (a text, maybe) and Voice Control will interrupt and start again. I use the top button to lock the phone, but it will override and start. I believe it has to do with the Home Button malfunctioning, because at the same time I have had the Voice Control issue, I am also having problems getting the Home button to work when I press it.
AZIANAPPLE
Jun 6, 2012
181
9
I hate the voice control function because it's so annoying!
I turned mine off. If your still having issues with voice control, I can help you turn voice control off too.
BabyWife
Aug 26, 2012
I'd love to turn it off. I never use it anyway. I am still having problems, although it is sporadic. I've looked through all the menus...how did you do it?!
AZIANAPPLE
Jun 6, 2012
181
9
On your desktop, go to this website:
http://www.i-funbox.com/
This program is a file directory manager for your iPhone. It works with all iProducts. It is 100% safe and reliable. Below is a description of the program:
Manage files on your iPhone or iPad in a way just like Windows File Explorer but more robust and friendly. Easily transmit files and folders to your computer with the optimized file transfer and browsing. iOS 5.1 is now fully supported.
AZIANAPPLE
Jun 6, 2012
181
9
This is the same thing as your windows file directory that you would use on your desktop when you press the "Start" button on the lower left corner of the screen on your desktop computer.
AZIANAPPLE
Jun 6, 2012
181
9
After you have downloaded the program, I will tell you the next step. Trust me it's very simple.
AZIANAPPLE
Jun 6, 2012
181
9
If what I have told you sounds a bit strange, that's alright :) I know this way is a tried and true method of permanently turning off voice control.
