Volume not consistent
D-Wade
Aug 26, 2008
69
Singapore
Does anyone experience this?
I set it to maximum, but after sometime, after I check i gone down, not fully down but lesser to what I have set it. Is this normal?
My friend iPhone has the same scenario.
Just asking... =):cool:
Saverino
Jun 1, 2008
4,480
92
Burbank
I have the same thing going on with mine. I don't think it is normal...It should stay set to whatever you set it to.
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
I haven't noticed it myself but it could easily be a hidden bug of the 2.0 software. I have to ask though, are you positive you're not accidentally hitting the toggle switch with your hand?
jptolife
Jul 15, 2007
645
New York City
It has actually happened to me a couple of times. Not many though.
smknSRT8
Oct 13, 2007
1,325
I have had it happen to me as well.
D-Wade
Aug 26, 2008
69
Singapore
i tried setting it to a minimum,
sleep mode, press volume up many times
check sound, still the same.
with the same setting tried to press
volume up on home, ringer bar goes up, checked
sounds, still at a minimum, but when press volume up on
sounds it automatically goes to maximum in one push of a button.
hmmmmm
BigCiX
Jul 11, 2008
1,445
Bakersfield, CA
i believe it goes up and down whenever you change the volume level from youtube and any other program that u can turn the volume up or down
cabinets
Jul 20, 2007
409
Atlanta Ga
This is a known bug and a pain in the a$$. The only fix is a restore and sometimes it takes several restores.
showguy
Dec 2, 2007
769
Long Island, NY
Add me to the list. Mine has been doing it since 2.0 on both my version1 phone and my 3g
Fairy_dust
Jul 11, 2008
30
I am having the same problem as I can't hear it ring on top volume in my handbag so I have no chance when it turns the volume down by itself. Nice to know I'm not the only one with this problem but Apple fix this soon
Lauting
Nov 11, 2007
49
London, England
I have this problem too....highly annoying but i think mine stays at max even though in settings > sounds the volume is in the middle.
ravman
Oct 4, 2007
1,197
Mean Streets of LA.
Are you guys also using a bluetooth headset? Turning the volume up and down on a BT headset, also raises and lowers the iPhone volume.
Ace4261991
Jun 18, 2007
530
well i know that when you plug in your headphones the volume automaticly changes to what you last had when your headphones were plugged in so make sure this is not the reason a lot of you guys are notices volume decreases. try it and see for yourself plug in headphones and put the volume somwere then unplug and watch the volume go back up
cabinets
Jul 20, 2007
409
Atlanta Ga
please listen. This is a known bug. The op's problem is a known issue. I've had four 3g's and three had this problem. A full restore fixes this and nothing else will. One phone took several restores.
