volume not working
saige1r
Mar 12, 2010
94
Has this happened to anyone else? Sometimes when I pull out my headphones, my speaker will stop working. I'm not sure if it's related to jailbreak or not, but I only noticed it AFTER jb'ing. It also happened on my 3G, which was also jb'd. Thoughts please?
Mboy
Jul 9, 2010
Happened to me as well but it's usually after a skype call. A reboot usually fixes it.
maximo916
Sep 17, 2009
193
What apps are you using when this happens?
When I'm using my headphones while listening to the iPod it does this. I assume the phone does it as a precaution, so if you're at work and the headphone comes loose your coworkers won't look at you weird when they hear Justin Bieber blasting out of your phone.
If your problem is that you can't get your speakers to work after you press play again, then it might be a side effect of one of your Jailbroken apps.
Flyfunner5
Jul 8, 2010
276
I have a different problem. My lower volume button is loose and moves around and I can hear it clank against the metal band. But I don't want to replace the iPhone 4 because I already put screen guards on the front, back, and sides.
Mboy
Jul 9, 2010
Mine isn't jb'ed and it happens. Am thinking it's a bug.
dblasgirl
May 22, 2011
9
Yesterday my iPhone 4S volume stopped working. It won't turn up or down. My phone only vibrates. I did a hard reset & I also reset it to original settings & backed it up on the cloud. Nothin has worked. The volume only works on the headphones. Can someone please tell me what I should do? I took the phone to my carrier and they said it would be about $200 to get a replacement phone from Apple. SOOOOOO NOT WORTH IT!
jcmitchell5
Feb 19, 2010
602
57
Arkansas
The carrier is wrong. I would just call Apple and tell them what is wrong and they will have you bring it in to an Apple genius and either fix it or replace it for a new one.
dblasgirl
May 22, 2011
9
I'm in Japan. The only way to get my phone to Apple is to ship it, but they are saying that I'm paying for a replacement phone.
dblasgirl
May 22, 2011
9
I will call them though & see what they suggest.
RoofMonkey
Jun 21, 2010
8,891
2,057
Silly question, but is the phone on mute? Check button on side of phone.
dblasgirl
May 22, 2011
9
No, the phone isn't on mute. I'm not getting my alerts. When I push the volume up or down buttons the volume symbol doesn't even appear on the screen. It's almost as if it's not making contact somewhere inside the phone. Even when I flip the switch for mute, mute symbol doesn't appear on the screen.
jcmitchell5
Feb 19, 2010
602
57
Arkansas
I see. Well Apple generally has awesome customer service and will replace your phone if something is wrong that was not caused by you. I am not certain how it would work in Japan though.
RoofMonkey
Jun 21, 2010
8,891
2,057
Try a hard reboot. Press and hold both the sleep and home buttons at the same time... Ignore the power off slider, keep holding them until you see the Apple logo. Then release both buttons. See if that helps.
If not you could try a restore.
dblasgirl
May 22, 2011
9
I have already tried both of those. I said that in the original message.
RoofMonkey
Jun 21, 2010
8,891
2,057
So you did... I missed that somehow.
Try inserting and removing the headphones a few times. Sometimes 'stuff' gets in the port and the phone thinks the headphones are plugged in.
If all else fails, try a restore as new and see if that clears it up. That would eliminate a software issue.
dblasgirl
May 22, 2011
9
Ok. I'll try. I did the headphone thing once, but I'll try it a few more times. I'll also try the restore as new if that doesn't work. I'll let u know how it goes.
Johnwolves
Aug 13, 2012
65
I had this problem and it was caused by a drop of rain getting into my headphone port. I solved the problem by gently cleaning it with a cotton bud
Sent from my iPhone 4s using Tapatalk
dblasgirl
May 22, 2011
9
Sooooo, I tried the cotton bud in the headphone port & the docking port. It didn't work. Thanks for the tip though. I hope something I try will work. I just don't wanna spend the $200 for a new phone.
Johnwolves
Aug 13, 2012
65
I'm sorry to hear the cotton bud didn't work. I hope you manage to find a fix for it but I'm at a loss as to what else to suggest
