Volume
Zookster
Sep 25, 2008
Hi all,
I try and set the ring volume on my new iPhone to max, as my hearing is not what it should be.
Within a short space of time, if I check the sound settings, the volume marker is back in the middle of its range.
How can I get it to stick?
Z
cabinets
Jul 20, 2007
409
Atlanta Ga
Are you using 2.1? That should've fixed this issue. If not, a full restore(maybe 2) will fix it.
Zookster
Sep 25, 2008
I just got it 2 days ago.
I have not changed it from out-of-the-box as in order to update it iTunes wants to be allowed to install iTunes 8 as well, which I have heard bad things about if used on a windows PC.
Is iTunes 8 safe now? If it was ever not.
scudder
Mar 4, 2008
174
Edinburgh
Not had a problem with iTunes 8 at all and been using it for a couple of weeks, like they said, 2.1 should fix the volume being changed when u use the ipod feature.
Zookster
Sep 25, 2008
Thanks.
Just to completely clarify, the volume reverts to 'middle' although I have not yet gone into the ipod function.....
BigCiX
Jul 11, 2008
1,445
Bakersfield, CA
What I did was set my YouTube volume up, volume up in the settings menu and all the way up on the side buttons. When you move the switch over to vibrate that might also adjust your volume without you knowing.
