Wallpaper App Not Saving Pics
x999x
Aug 6, 2007
1,656
Add my Repo to your Installer sources and locate the Wallpaper fix. You may need to restart your phone after applying the fix, but it shouldn't be necessary (some users reported it worked after a restart for them.)
http://dezign999.com/repo
I've also added the iShare preferences saving fix if you use that app.
Hondamaker
May 14, 2007
9,939
665
55
Fairborn, Ohio
dude, I've had your repo for a while, I've appreciated your contributions. I'll look for ishare and see what happens.
x999x
Aug 6, 2007
1,656
Add i-app-a-day to your sources, it should be listed for install under Sources.
Basically it connects you to a central server of others that are also running the application. Once connected, you basically watch a slideshow of everyone's current wallpaper set on their iPhones. If you see one you like, just tap the screen to add it to your wallpaper library or camera roll.
Its kind of addicting, I just leave my auto lock off and let'er rip while I'm sitting at my computer. Its really cool to see one of your wallpapers make circulation, especially when you've not had it as your own for some time.
