Wallpaper won't change
iErik
Oct 27, 2007
1,221
72
Las Vegas, NV
Title says it all. I'm on 1.1.4/ZiPhone. Any suggestions?
thepunisher1991
Jul 30, 2007
72
well my suggestion has 2 steps
1. Click on the search button on top and right in the search box you problem and you will find what you need because there are a lot of people with that same problem and they all have answears
2. If you don't find anything then you post the thread because no one going to reply to this question
Cusca
Apr 27, 2008
320
ROMANIA
www.cusca.3dk.org
you used customize rigth ? i`m guessing you did, well here is the fix, but for the future make sure you don`t set up a wallpaper in custozie,
you have to delete the file the customize set up manualy, via ssh, or any other method that u use, here is where you will find your file private/var/mobile/Library LockBackground.jpg delete it and then just use whatever wallpaper you want
iErik
Oct 27, 2007
1,221
72
Las Vegas, NV
I don't remember setting a wallpaper in customize but that worked. Thanks.
Cusca
Apr 27, 2008
320
ROMANIA
www.cusca.3dk.org
well if you applyed a there in customize it automaticly applyed the wallpaper of that theme, so be careful next time, don`t press apply theme press apply only and apply everything but the wallpaper
