Want to track lost iPad
rugved1118
Sep 27, 2013
642
Hello..
Is it possible to track a lost ipad without installing find my iPhone app installed ?
Sent using iCafe app
28,365
5,506
Hello..
You don't have to install an app. Find My iPhone can be enabled in the Settings app. It can't be tracked if you didn't enable it before you lost it.
rugved1118
Sep 27, 2013
642
If its enabled i can track from Apple site using Apple id... Is it ?
RoofMonkey
Jun 21, 2010
8,880
2,049
If its enabled I can track from Apple site using Apple id... Is it ?
Yes, if it's installed (older iOS versions had to be installed ) and it's activated, you can to iCloud.com, sign in using your Apple ID, then select the Find my iPhone app.
