Want to turn my iPad 2 into laptop
doinitmyway
Apr 14, 2011
Which of the wireless keyboards that connects to the iPad 2 to make it look like a little macbook works best? There are a number of them out there now. A few are $149. A few are $49. I want mind to have protection for the top and bottom and to have a USB connection.
I'll be interested in replies to your question as well.
A girl I work with just got an Asus tablet. She had this snap-on keyboard which folded down over it and basically turned it into a netbook. The trackpad even had two-finger scrolling, which I thought was pretty cool. The downside was that it was top-heavy. I think she said it was $149. I don't think there is an iPad version of a keyboard like this (with trackpad) available, but I could be wrong.
doinitmyway
Apr 14, 2011
The guy on my job that sits in the cubicle next to me has that same Asus tablet. He just purchased the keyboard. That's how I got interested in getting a keyboard. His keyboad has a USB connection. That is what I want, the USB and the trackpad. There are two keyboards for the iPad 2 out there for $149.00.
Apple iAddicted
Feb 20, 2012
269
27
if she can open the casing and add some stick on weights inside below the trackpad section it will totally solve the topheavy issue a few ounces will work wonders
Sent from my 32GB iPhone 4s on iOS 5.1!
Only thing iPhone is missing is an expandable memory port! Come on Apple give us a microSD port already!
  • Like
Reactions: doinitmyway
doinitmyway
Apr 14, 2011
Apple Addicted I so agree. It would be nice to have a microSD port, and Target that particular case that you have seems to be a popular one. I may have to look into it more. Not sure if there are any keyboards for the iPad with USB ports, Thought I saw one but it does not protect the front and back of the case. I need front and back protected.
Target
Oct 16, 2008
1,139
161
The Great State of WV.
I put a zagg leather skin on the back of mine. I also have black leather smart cover. It gives scratch protection with or without the keyboard.
Target
Sent from my iPhone 4 using iCafe app
Chancellor
May 28, 2011
280
24
I was soo close to buying that other tablet, glad I chose the iPad (for now at least). In another thread someone found one on eBay and I'm awaiting his response on now it is. Dent really look like a lil MBP but I'm sure anything that looks like a MBP converter is probably out of my price range lol.
GADeputy
Jan 21, 2008
381
Georgia, USA
I answered your post on the other thread. :)
iP5
Sep 7, 2010
2,964
136
Toronto
@Europa
I'm surprised you found the Transformer top heavy. The battery in the keyboard is almost as large as that in the tablet. I do find the hinge action is heavy which may have given you the top heavy impression but they had to do that because the tablet is detachable. Also unlike a laptop, the top section is more than just display so...
In addition to the USB port it also adds a full size SD card and USB support for external drives. Not that that particular device as is would interest you. It might run Ubuntu though, not sure.
The New Transformer does SDXC support maxing it at 160GB between the onboard/microSD/SD ports.
Sent from Tapatalk
eye-Fone
Jul 5, 2008
1,024
14
Sunny, southern California.
Items to consider:
• Is it plugged into a computer via the USB cable?
(many PCs' USB ports don't have enough power to charge the new iPads)
• Is it plugged into the same charging unit that came with the iPad?
(other third-party chargers may not have enough power to charge the new iPad. iPhone chargers are weaker, but will charge them, albeit *very* slowly)
• If the charger is plugged into a power strip or a switched wall outlet, is the strip or outlet turned on?
(I speak from personal experience!) :-(
Sent from my iPad 3 (64GB)
