way around putting movies into iTunes
misunderstood
Aug 17, 2007
i just spoke to an Apple technichian over the phone and he said that since the last update to iTunes they have been cracking down on what movies you can add to the library because of their agreements with the movie companies so i was wondering if there was a way around putting my mpeg 4 movies files into iTunes to get them on my iPhone. thanks.
wildonrio
Jul 4, 2007
2,002
Provo, UT
I bet you could do it if you knew what directory the videos are put into on your iPhone. Then you would just use Manzana, iBrickr, or WinSCP and transfer it over.
Hondamaker
May 14, 2007
9,946
655
58
Fairborn, Ohio
Been puttin movies on my iPhone since the last update with no problem, using iTunes.
Atlas
Oct 14, 2007
88
How do you put movies on the iPhone. I put a dvd into our new iMac and it played the dvd but I could not figure out how to load it into iTunes so it could be synched to the phone.
tmoce
Oct 10, 2007
My way around it is that I download movies in AVI format, and then use Videora to convert it to MP4. I heard around this post you can copy DVD using that same program. I’m too lazy to burn DVDs so I just download them. I currently have the Simpsons movie and the Hannibal Lecter movies on my iPhone. Hope it helps
doron
Apr 17, 2007
1,141
tampa, FL
or you can download this program called handbrake @ handbrake.com and convert your dvd's into mp4 in there...then once you convert it, you copy it into iTunes, THEN...lol...you have to select the mp4, go to Advance and click on convert selection for ipod...and the process begins...now the process takes a while...and when i say a while, i meen A WHILE...so i hope you got some patience...and then when you go to sync, just chk the movie...and there it is...
scandalex
Sep 16, 2007
771
New version of Videora available as of today.
