Weather app location services
VOLS34
Jun 25, 2010
1,119
79
Anybody having issues with the weather app being off on location lately?
Sent using iCafe app
Smarty2600
Apr 23, 2011
344
11
Yeah I've been having some issues the weather app is showing a nearby city not my city where I live. I haven't been able to fix it yet. I did a hard reset and turned off the location services and then back on but no change. My next step will likely be to reset location services if the problem doesn't fix itself.
Rafagon
Dec 7, 2011
7,566
1,254
44
Miami, Florida
Have you tried adding your city by name (tap the "i" on the lower right-hand corner of the screen), instead of relying on the GPS... Just for now, so you have a way to retrieve the weather for your city, until everything goes back to normal for you...
Smarty2600
Apr 23, 2011
344
11
Yeah I have my city typed in the weather app. Thanks for the tip though and it does show up in the weather widget on the notification tray when I have location services off for the weather app. But I'm just a stupid perfectionist that wants to solve problems even when I can't.
