Weather(deleting cities/towns)
K33pcalm
Sep 23, 2013
How do I delete cities/towns from the pre-installed weather icon? I have a 4S, using iOS7. I could them delete before, AND there was a list of my city/town selections too!
Dec 10, 2009
2,589
1,337
52
Clarksburg, WV
There is a small lower case i, bottom right hand corner.
Tap it, it takes you here:
Where you can manage cities...
28,365
5,506
Swipe from right to left on the city you want to delete (just like you do in the mail app) and a delete option will appear.
Dec 10, 2009
2,589
1,337
52
Clarksburg, WV
Also, in iOS 7, there is a small menu icon, lower right corner:
Tap that and you will go to the similar menu as above.
28,365
5,506
K33pcalm
Sep 23, 2013
That worked! Thanks a-bunch!:D
