Weather Icon
Tug
Aug 4, 2008
528
Is there any way to change the default location on the weather icon from Cupertino CA to lets say where I live? I realize Apple is located there but it's a pain wanting to check the local weather and having to constantly change the default location in order to do so.
miggs1310
Jul 29, 2008
426
tap the little "i", you can add and delete locations from that menu. the one you enter first will become your default.
smknSRT8
Oct 13, 2007
1,325
Its an easy fix. Open the weather application, Click the "i" in the lower right hand corner, delete any cities that you don't want and add the ones that you do, and you can move them around accordingly. I believe that the first city is going to be the default.
dcom
Aug 7, 2007
1,421
Suwanee, GA
Just tap the "i" in the lower right, add your location, then delete Cupertino. The icon itself is generic, not location-specific.
Tug
Aug 4, 2008
528
Hot damn... it worked!
Thanks guys :)
smknSRT8
Oct 13, 2007
1,325
Gotta love getting a qeustion answer by three different people in a matter of 5 minutes. Damn are we good!
Tug
Aug 4, 2008
528
Never a doubt in my mind :)
nobopyon
Jul 11, 2008
393
Dallas, TX
LOL..
or should we say... "get back to work!" :pP
oops... i should tell that to myself.. :p
dcom
Aug 7, 2007
1,421
Suwanee, GA
Actually, the default city will be the last one you looked at before you closed Weather. I have 3 and if I look at hte 3rd, then close it, the 3rd will be displayed when I bring it up again, even if I completely shut Weather down by holding the Home button for 8 seconds.
