Weather won't update?
SoccerSpartan20
Jul 4, 2007
32
Hey guys, i'm fairly new to this website (and I've already peaked around to see if this topic is already posted) but I was wondering why my weather and sometimes stocks aren't updating. My EDGE seemed to work fine last week, but ever since the update (which seems to be causing more bad than good!) I've been getting really really poor connection when I still have 5 bars listed on the top left for AT&T service. Even when I try to go to cnn.com or some other easy website, I seldom get the message "Safari can't open the page because it can't find the server" ... it's frustrating; i see the little blue progress bar go about a quarter way, but it never loads the entire thing, and thus prompting the error message. It's not because I'm in a dead-zone because I can receive telephone calls just fine (and the aforementioned 5 AT&T bars) so I'm just trying to figure out what I should do. Any advice?
SoccerSpartan20
Jul 4, 2007
32
okay I lied..
alright, now NOTHING will update... what is up with EDGE? I go to email and it says "connecting...." forever, and then weather it says "updating...." forever and finally says "Update failed"... I hope it's just a bad day for me and this will get better soon.
Aug 3, 2007
11
Try reseting the phone or restoring it. You might want to call Apple for a replacement. Maybe the antenna is defective or something. Also does it work on wifi.
SoccerSpartan20
Jul 4, 2007
32
thanks!
Reseting it did the trick! thanks a lot. I should have tried that originally.
