webguard webcam
Mar 4, 2008
Does anyone know how to access a webcam site using the iPhone? Does additional software need to be down loaded? Help!
fury
Oct 23, 2007
2,274
238
33
Louisville, KY
If the site requires flash or java, it can't be done on the iPhone just yet. But if it's just a simple auto-refreshing image, you should be able to use it. Simply enter the address in Safari and go.
Mar 4, 2008
thanks for the quick reply. i guess that must be my problem. i had to download an enigma browser on my home computer in order to view it. can that be done with the i phone?
fury
Oct 23, 2007
2,274
238
33
Louisville, KY
Technically, you can't download applications to it unless you modify it (which voids your warranty)
Ignoring that, there most likely will not be such a client for the iPhone. You will have to check and see if there is a web page interface for it that uses just a regular image.
