Weird Iconoclasm Behavior with folders
Santa
Jul 2, 2009
1,122
115
Colorado, USA
I've been playing around with Iconoclasm. I managed to make a free form layout, but when I started using it, I found that folders didn't work well. This is what I got:
Stuff doesn't scroll up so I can see all the icons in the folder. I went back and checked the included "free form" layouts and they did the same thing, so it's not just my layout.
Anyone have a clue? Does iconoclasm just not really work any more?
Thanks.
iphonewarrior
13,847
699
The last update doesn't mention anything about any folder fixes unfortunately.
Send the Dev an email.
Are you using Skrink?
iphonewarrior
13,847
699
Iconoclasm is good for some people though because you can have custom layouts. Gridlock only allows you to put icons in a grid styled fashion.
I've personally never used Iconoclasm, it looks good but Gridlock's makes much more sense to me.
Santa
Jul 2, 2009
1,122
115
Colorado, USA
yes, I was hoping to do some layouts that were a little more free-form. But looking cool doesn't do much if it doesn't work.
I sent a note to the developer. I'll see what I hear back.
Santa
Jul 2, 2009
1,122
115
Colorado, USA
Heard back from the developer:
"I am aware of the issue, I just haven't found a fix that works yet. One solution would be to get FolderEnhancer, which does away with the sliding mechanism entirely and displays folders as a pop-up over SpringBoard."
Gridlock's looking better.
iphonewarrior
13,847
699
It's good that the Dev got back to you! Glad that Gridlock's working out for you (which works with both FolderEnhancer and Shrink).
fijiman
Feb 13, 2011
832
64
UK
Gridlock + CustomGrid + (Shrink or Bigify+) = Any layout you can imagine...
CustomGrid a nice tweak a max of 144 apps on the springboard plus more......
fijiman
Feb 13, 2011
832
64
UK
CustomGrid-Strange.....been running it since it came out....my iPhone is very tweak heavy never experienced any lagging .... even though I have nothing showing on my springboard I still have it installed...:)
iphonewarrior
13,847
699
It was probably conflicting with something I had installed. My phone didn't crash, just slowed right down.
Do me a favour send me a list of your tweaks, I might be able to find out what the problem was.
fijiman
Feb 13, 2011
832
64
UK
In the process of Restoring iPhone... still installing one or two bits...just finished installing ScrollingBoard from Cydia after pics were taken....
