Weird iPhone behavior sometimes
rgarjr
Nov 19, 2007
34
The iPhone jailbroken on 1.1.4.
This happened to my phone like twice, the phone will get No Service from ATT, no audio is heard from ipod music, videos don't play, and when you type with onboard keyboard its really slow.
Don't know if its an app causing this bug or what. Seems like restoring the phone will clean it up.
AntonChigurh
Jan 30, 2008
226
You should ask this question in the iPhone Modifications forum, you'll probably get a better answer faster there.
Alexander
Jun 28, 2007
1,724
Atlanta
Do you reboot the iPhone daily? Sometimes laggy performance is caused by not rebooting.
As for the rest, you may have installed an application that is acting buggy.
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
I would try doing as Alexander suggested and reboot the phone. If that doesn't seem to clear up the problem then the lag is likely due to 3rd party applications. I would suggest you back up your information and restore the phone and start anew with the applications.
adseguy
401
That's a band-aid fix guys.:p
If you restore and try going un-jailbroken for a while and it still does this then return the phone. You may have a bad proc. or memory chip.
iPhone have a pretty solid OS platform here and they don't need to be reeboted daily or even weekly like Palms or even worse Wondows mobile devices. Mine gets buggy once in a while too (totaly normal...programmars aren't perfect) but it takes a few weeks that's for sure.
