weird, my visual voicemail just stopped working
ATT*Mark
Jul 7, 2007
273
today when i went to check my voicemail i clicked voicemail and it dialed the classic voicemail , then it asked me to set it up.... how do i fix this?
Alexander
Jun 28, 2007
1,724
Atlanta
After I did I restore to my iPhone, my Visual Voicemail is no longer working as well. Same issue.
qlock
Jul 2, 2007
I thought you worked for AT&T?
wouldn't that be on your guys' end?
Anyway, I'm sure you already rebooted again (after restore cycle), so my guess would be a network issue, like the vm sevice down in yor area at the time or your reception was bad at the time.
ATT*Mark
Jul 7, 2007
273
yes but att doesn't troubleshoot visual voicemail.....
ATT*Mark
Jul 7, 2007
273
ok ive been on the phone with Apple then att , then Apple some more , then back with att. somehow the visual voicemail SOC was deleted from my account but they are having trouble adding it back , how weird......
wjp09
Feb 25, 2007
2,559
25
NJ
Happend to me all you need to do is go into the preferences menu *while calling old school voicemail* and set it up. After you set everything up it comes back.
It did for me anyway. However it keeps saying WRONG PASSWORD however I just ignore that.
ATT*Mark
Jul 7, 2007
273
i did all that, did a restore , soft and hard resets nothing worked, att had to remove my iPhone plan and re add it for it to come back , super weird but its fixed now.
