What apps DON'T work on jailbreaked 1.1.3?
phillyphill39
Dec 30, 2007
146
Because i have customize running on my 1.1.3 along with summerboard (it just doesn't skip the last row :/)
you can get most 1.1.2 programs to work on 1.1.3 jailbroken firmware
o ipod/iPhone system/library/coreservices/systemversion
and then you will see this
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple Computer//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>BasedOn</key>
<string>Tahoe4A86</string>
<key>ProductBuildVersion</key>
<string>4A93</string>
<key>ProductCopyright</key>
<string>1983-2007 Apple Inc.</string>
<key>ProductName</key>
<string>OS X</string>
<key>ProductVersion</key>
<string>1.1.3</string>
</dict>
</plist>
where it says 1.1.3 change it to 1.1.2 and save it, and there you got. it will make it seem like your on the 1.1.2 firmware but not really.
seb481
Aug 3, 2007
774
San Diego
<dict>
<key>BasedOn</key>
</dict>
</plist>
So by using this fix, you can get summerboard and customize to work on 113? You can change backgrounds and dock image?
Erica Sadun's Make it Mine doesn't work. It crashes when you try to change the carrier logo.
- John
