What are the chances i can get my iPhone replaced?
Apr 12, 2008
21
Houston, Tx
I have two lines of discoloration coming from the carrier and from the battery icon. I also have 2 chips in the screen, my iPhone is unlocked and jailbroken on T-mobile.
Youngbinks
Jun 4, 2007
7,617
32
Atlanta, Georgia
Has the phone been dropped and do the lines of discoloration seem to be a result of said drop? If so Apple might claim that it was user wear and tear and charge the $250 replacement fee.
themanofthedark
Jan 5, 2008
2,674
26
Boston
go to AT&T.
open up a pay as you go account.
call Apple.
set up an appointment.
after they give you the new one, try activating it with that sim, and when it fails (which it will) tell them to call AT&T, and tell them you activated the iPhone with the pay as you go account.
they will then tell you you will need a new one, and after which, just ask to be given a new sim and tell them you need to go.
oh, a bit of advice. before that, go to 1.1.1, then use ZiPhone to Do it All. the Installer icon will not be there, and it will be hactivated.
you didn't get these instructions from me.
