what can I do if I want to upgrade
thepunisher1991
Jul 30, 2007
72
If I want to upgrade to 1.1.3 do i have to restore my iPhone first then upgrade or just go to iTunes and just press update
If you're jailbroken and you want to clean out all of the modified stuff, Restore first. If you don't care what's left, just update. You will loose you modifications regardless, and you'll have to re-jailbreak, should you want to.
- John
michael180
Jun 14, 2007
1,249
Santa Cruz, CA
moderntimes.com
- John
I thought as much. But if I do as recommended above, and re-jailbreak I will be in the same fix? The bottom line, I suppose is that if I want a jailbroken 1.1.3., as I have now, I'll have to do without YouTube? You would have though somebody out here would have a patch for this.
Thanks,
Michael
Bone
Feb 11, 2008
1,214
I do believe there is a patch for this.
michael180
Jun 14, 2007
1,249
Santa Cruz, CA
moderntimes.com
Thanks,
Michael
I actually posted this in the wrong thread. It should have been in the "iJailBroken 1.1.3, no YouTube?
Sorry
