What do you think of battery phone case?
echo2012
Sep 4, 2012
I am considering to buy a battery phone case, but I wonder if it really work? Do anybody use this kind of case before? Tell me about that , please .
IllusionEntity
Jun 3, 2010
1,990
163
Borough Green, Kent, UK
If you are looking for a decent battery case I would go with Mophie. They have the only cases that I have used that sync the iPhone while its in the case. Also the juice pack air from 0% can take my phone back up to around 76%
Sent from my iOS EcoSystem
mrgadget
Aug 28, 2007
I'm using the Third Rail case. I liked this better than the bulky battery cases as the case itself is light and slim, but allows you to snap on a small battery to the back only when you need it. It also gives you a micro-usb connector and you can buy multiple batteries. Also, as new phones come out, you just need to replace the case, as the batteries will work with their updated cases. The downside is that you have to make sure you have the snap on battery with you in a bag or pocket:)
rambo47
Apr 4, 2010
528
79
Northern NJ
I use a Mophie Juickpack when I'm going to be out for more than a day and away from a charger. It adds considerable bulk to the sleek iPhone design but it's awesome for extending battery life.
echo2012
Sep 4, 2012
thanks for your experience sharing
echo2012
Sep 4, 2012
Your reply helps a lot, thank you very much.:)
echo2012
Sep 4, 2012
:eek:
