What does enabling Location Services do?
trido
87
What exactly does turning location services on and off do?
Is this the GPS only?
If yes then when left on all the time is this a large battery drainer?
dturner
Dec 15, 2007
5,725
Louisville, Ky.
It is also used for the "locate me" function of maps. I don't think it has a lot of effect on battery drain.
kevlar08
Jul 3, 2008
1,140
Colorado
just to enable location on location based apps i believe
JanL
Aug 26, 2010
54
Oklahoma City, OK
I can't find location services under setting? I have updated to ios6. Any suggestions?
djwindsor
Jul 7, 2009
755
44
Neponsit, NY
I have always kept location services on with past iPhones. I have a question regarding this setting on the iPhone 5. I have noticed the location icon appearing even though I have no GPS apps running. I know the culprit is REMINDERS as the icon is the one which has no fill. My question is whether this type of usage will drain the battery the same as if I was using a GPS app for driving guidance.
