What does the E mean
butur
Mar 10, 2009
Up in the left corner, where the wi-fi signal is, it some times comes up an E , what is it and what does it do?
Michael Baturin
Jul 11, 2007
1,750
244
32
South Jersey
Edge is one of 2 networks used by AT&T. This network is what allows you to make phone calls and connect to the internet. The other network is called 3G, this network is what the iPhone 3G uses (obviously), and can be considerably faster than edge when surfing the web, depending on your location.
Further explanation at Wikipedia here: http://en.wikipedia.org/wiki/iPhone
Ezekiel2517
Sep 20, 2007
693
actually, theres three. the other is GPRS, represtented by the "o" on the iPhone
GPRS- 1G
EDGE- 2G
3G
or...wait, itsnt edge 2.5g? idk... its something like that
but yeah, you get the point..
Michael Baturin
Jul 11, 2007
1,750
244
32
South Jersey
GPRS- 1G
EDGE- 2G
3G
Woops your right, sorry for the misinformation.
butur
Mar 10, 2009
Ok thanks, i thought it might be edge but it's turned off so i wasn't quite sure
dturner
Dec 15, 2007
5,725
Louisville, Ky.
If you are on wifi and for some reason get a weak signal, the phone will switch to edge until the wifi signal is stronger.
quintin
Jun 22, 2012
would it charge me on my bill phone if it show up?
RMWeins
Nov 27, 2012
You may also be receiving the E if you have 3G specifically turned off. Go to Settings - General - Cellular, and make sure Enable 3G is turned On.
