What if I have to restore my jailbroken 1.1.1 phone after 1.1.2 comes out?
jaydoc1
Sep 23, 2007
608
If I would have to restore my phone, how do I keep it a 1.1.1 phone and not update to 1.1.2? I can't remember when I updated to 1.1.1 is there an option to download or not download the newer version?
Josh
Jun 9, 2007
there is no option in iTunes when restoring. if you restore, it automatically defaults itself to downloading the latest firmware.
Stevonw
Sep 14, 2007
560
UK
You can downgrade to whatever firmware you want, provided you have the file on your pc/mac and follow the instructions.
bfakhroo
Oct 2, 2007
132
you should have the file of the firmware you want to restore to in the computer and when you open iTunes press SHIFT + (the restore button) a browser would come out and choose the firmware file that you have on your computer
jaydoc1
Sep 23, 2007
608
Thanks, can you or anyone tell me where that file is located and what it's called so I can copy it somewhere just in case?
bfakhroo
Oct 2, 2007
132
i'm not sure where exactly where you can download it but search in the forums you should find it i once downloaded version 1.0.2 restore folder from a forum.but i don't remember which one just try to search and you will find it or maybe some one can tell you directly where to download it from.. good luck
jaydoc1
Sep 23, 2007
608
Never mind, found it on the net.
Thanks!
firewire
Nov 4, 2007
941
17
Hi, I am new to the iPhone and have yet to play around with any changes. I would also like to have a saved version of 1.1.1. Where did you find 1.1.1 to download? Unless there is another way to get 1.1.1 saved on the pc? Thanks for the help!
skiz420
Jul 28, 2007
371
Boston
if you are on a pc they are located in
C:\Documents and Settings\****USER NAME HERE****\Application Data\Apple Computer\iTunes\iPhone Software Updates
vtec236
Sep 11, 2007
22
Colorado
ok so i have been away for awhile and not sure where i read this but i was under the impression that if i restored my iPhone with the 1.0.2 firmware off Apples site it would set my phone back to stock meaning "locked" so i did this and noticed that 1.1.1 was jailbroke so i figured let's do this. Well i'm screwed now i used the iunlock method for windows for fun since i have been and still am a AT&T customer. Now that i realise that i should have done some research i have the 0049 imei number. Is there anyway to change this in 1.1.1? i have it jailbroke again and anysim 1.1 has done it's magic but i need to change the imei so it will read the stock sim that came with the iPhone
Stevonw
Sep 14, 2007
560
UK
Woah, v1.1.1 is much bigger than v1.02!
