What is a "bricked" iPhone?
Gundam01
Jan 18, 2008
19
What is a "bricked" iPhone? What are the symptoms or tells that it is? Is my phone bricked since it's only showing the connect to iTunes? I have a unlocked/ jailbroken v1.1.2 iPhone and decided to update to v1.1.4. When I did, it just shows the connect to iTunes image. Do I have to have the sim card inside when I update or restore or when I use ZiPhone? My phone is brand new and I haven't even used it to make a single call that's why. Thank you for all your help!
A bricked iPhone defines it as just that - a brick. The screen is black, you cannot get it to turn on, it cannot be used, you cannot call it, iTunes does not recognize it, etc.
The screen you see signifies that the phone is recovery mode - you have to Restore to get out of it. Leave the SIM in, Restore in iTunes, and then use something like ZiPhone to re-jailbreak and re-unlock it.
- John
Gundam01
Jan 18, 2008
19
iPhone questions....
- John
Hi thanks for your response... But do I have to have the sim card inside in order to perform that operation? Or can I just do it without since it's still brand new? How do I open it anyways? I heard from my friend because she has one too that the people at AT&T didn't even put a sim card inside her phone so I was kinda tripping that she said that. Does all iPhones have a pre-installed sim card inside already? Thanks again.
themanofthedark
Jan 5, 2008
2,674
26
Boston
it does not matter if you have the SIM card in it or not, your effects will be the same.
iPhone come with a SIM. It's located at the top between the lock button and the jack - that little slot. Just push a paperclip into the little hole and it'll pop out. But as Sam said, the SIM is not necessary for a restore.
- John
Gundam01
Jan 18, 2008
19
iPhone not working...
Hey Sam! I tried restoring it with iTunes but after the long download time, I ended up with an error message "iPhone could not be restored. An unknown error occurred [-50]". What am I doing wrong? All I did was click on restore and update on iTunes.
themanofthedark
Jan 5, 2008
2,674
26
Boston
hm. error -50..
Thats... not a common error.
Have you tried restarting your computer, installing the newest iTunes, and trying once more?
also,
Mac, or PC?
Bone
Feb 11, 2008
1,214
also maybe trying a diff comp might help as well.
Gundam01
Jan 18, 2008
19
hm. error -50..
also,
Mac, or PC?
Hi. I'm barely re-doing it right now. Just rebooted and now waiting for the new updates to iTunes to install. It's a PC. What's the website for ZiPhone again?
Gundam01
Jan 18, 2008
19
Next in the agenda...
So finally I just re-unlocked my brand new phone and now I'm trying to install apps into it. The problem is that it can't seem to find a host. Does my phone have to be activated with a working sim card and all? I tried hooking up via wifi but everytime I do, it can't seem to recognize the password eventhough I changed my wireless modem's password twice just so I can hook up to it. Are there apps that I can install just by using the usb cable (not on my comp of course)? Also, where do I get a copy of Spring Board (or is it summer board now) and NES apps? Much obliged...
Gretchen
Aug 17, 2010
I need help. ok a lot of people had told me to jailbreak my iPhone4 because i want to use my device as a wifi but i want to know the consequences, it's too good to be truth. Also i have read about the bricked iPhone... omg i'm so new at this and i got it like 3 days ago. It worths doing the jailbreak or is best paying the tethernet? Please SOS thanksss!
Babyt
May 24, 2010
1,013
64
Well if you JUST want to jailbreak your iPhone to use it as a wifi hub (or whatever) then go for it.
I think the real danger is downloading unsecured packages. And if u use someithing like mywi, that's just being raved about, then you should be problem free.
I jail broke my iPhone 3G.
And I'm back to using it normally. I'm bout to redo the jailbreak because I loved all the awesome features of jailbreaking.
-sbsettings
-winterboard
-bitesms
- catergories
-backgrounder
Just to name a few :)
Any ways I probably didn't help much. Sorry:/
Gretchen
Aug 17, 2010
heyy
well thanks! i jailbreak my bf's iPhone 4 and everythng work perfectly. how can u take out all the jailbreak and the cydia from your device, like using again your iPhone normally?
Babyt
May 24, 2010
1,013
64
You have to restore it on iTunes to a backup of the phone.
