what is best DVD to iPad converter
sbynyc
Jul 31, 2007
40
Hi all. There's so many of these out there. I don't know which one to get and I was wondering what the consensus is on this forum. I'm not necessarily looking for free, I just want one that does the job. Thanks.
X
xiaoa10
Guest
Thanks, I'm using Win7. I wonder if there's a Handbrake for Windows.
Hi, sbynyc, Handrake can works on Windows OS. though Handbrake is very popular, You need to set specific parameters by yourself, However, if you try Aneesoft DVD to iPad converter, you just choose one of the iPad format, and you can export the video, works easier. Of course, you also can try both of them. Finally, the former is Free,the other is paid.
besweeet
Jun 7, 2009
968
26
San Antonio, TX
briansweet.me
I also use Handbrake. A bit slow on my 2.66GHz Core 2 Duo when using the x264 codec, but the result is amazing. I usually add everything to my queue and convert everything overnight. Great app. It has recently received an update, and I swear it's slightly faster at converting.
I also use it to convert 1080p/720p BRRips over to a 720p MPEG-4, which plays fine on my computer, iPhone 4, and iPad.
