What is Edge?
eltocliousus
May 7, 2008
40
I've had my iPhone for about 2 months now and i cannot figure out what Edge is? I use Wi-Fi to connect. I've googled it, searched the forums. Everything. So what is Edge? And thanks for the help, have a great evening - Eltoc
EDGE is the data network that your carrier provides. If you have EDGE, you will see a little box with an 'E' inside of it beside your carrier logo.
- John
eltocliousus
May 7, 2008
40
I don't think I will be using of anyway since It costs but thanks
Mar 30, 2008
5,126
Elizabethtown, Kentucky
This may seem irrelevant, but on my HTC 8125. Sometimes the "E" will change to a "G", and go back and forth?
psylichon
Oct 31, 2007
16,591
751
41
Philly
This may seem irrelevant, but on my HTC 8125 Sometimes the "E" will change to a "G", and go back and forth?
G means GPRS. That is a 2G (second generation) network. Edge is an extension to GPRS, or 2.5G as they say.
When you can't get Edge coverage you will switch to GPRS. GPRS maxes out about 60kbps, while edge can go up to 200 but averages around 128kbps.
Mar 30, 2008
5,126
Whats really weird is that sometimes when I come home, and dock/cradle my HTC, it will have access to edge in this really weird part of my room, facing a direction that you would never think to get service, but when moved will go back to GPRS:eek:
soloudinhere
Jun 18, 2007
157
For the record:
Voice calling is 2GSM, GPRS (General Packet Radio Service) is actually 2.5G, and EDGE (Enhanced Data for GSM Evolution) is 2.75G.
EGDE actually sort of falls under the 3G definition, though not as we know it with UMTS, HSDPA, HSDPA+ and the upcoming HSUPA which will actually make 3G truly functional.
