What is safe mode?
scholls22
Jul 15, 2008
58
Just jailbroke the phone two days ago for the first time. My phone just vibrated and had a picture of a phone crying...It said something about springboard crashing and the phone would be in safe mode...Whats up with all of this?
guest03
Mar 30, 2009
80
safe mode usually means that a program that you have downloaded is not compatible with the OS you are using. Safe Mode gives you the ability to remove the software more than likely the one u downloaded before it went into safe mode. Once that is done, simply restart your phone.
scholls22
Jul 15, 2008
58
Thanks! I appreciate it. I was worried that it was some type of bad app that i downloaded and my phone was dead now!
