What is SSH?
Shotta876
Sep 16, 2007
75
Sorry, I'm a tech idiot.
michael180
Jun 14, 2007
1,249
Santa Cruz, CA
moderntimes.com
SSH is a method of communicating with your phone via FTP. You can upload and download files with SSH. If should do a search here, and you will get tons of information. You should learn how to use SSH. It's very useful.
Good luck
Y-Less
Feb 28, 2008
149
Netherlands, The
Good luck
Secure Shell or SSH is a network protocol that allows data to be exchanged over a secure channel between two computers. Encryption provides confidentiality and integrity of data. SSH uses public-key cryptography to authenticate the remote computer and allow the remote computer to authenticate the user, if necessary.
SSH is typically used to log into a remote machine and execute commands, but it also supports tunneling, forwarding arbitrary TCP ports and X11 connections; it can transfer files using the associated SFTP or SCP protocols.
Read more on Wikipedia
