what should i install from installer?
MiPhone7012
Aug 10, 2007
121
Seattle, WA
well theres tons of options what do u guys have and that you like? and what should i stay away from? thanks
jUeLz23
Sep 4, 2007
350
it all depends on what u want to do to the phone.
jus go through the apps in installer and read the description and go from there.
Saurabh
Sep 5, 2007
152
VA
Well i think downloading games are useless. But apps like AIM, the ring tone pack is cool, wallpaper packs, just stuff that you know that would make your iPhone usage time more fun.
Jul 17, 2007
14
installer "Ringtones"
is it me or did the installer only add a few ringtones. I was hope a ringtone pack was at least 6. :(. They were kinda dull, I uninstalled
zenazazel
Sep 12, 2007
14
Summerboard and rSBT for sure! with those two you're all set. Mobilefinder is good also. It will help you change custom icons on the fly whenever youre away from your computer....everytime an app updates you can have your own nice custom icon instead of the crappy one some of the apps have ;) it also allow you to set persmissions.
Another cool app is dock swap.
jbarrack
Jul 2, 2007
453
New York
www.facebook.com
Right on ... Summerboard rSBT are awesome. I also like Dock 2.0 its really great. With rSBT you can hide all your apps to clean your home screen and access them with Docks 2.0
Do not install XLaunch. I tried 3 times and every time it deleted all my apps and I had to Restore and re-install AppTapp.
Check out Sketches, VNotes, Summerboard, Dock, and DockSwitcher(something like that). They're all pretty neat.
