What's the path from OOTB 1.1.2 to 1.1.4?
GolfNut
Oct 15, 2007
I've seen this question asked a few times in other threads without an answer.
If you have an OOTB 1.1.2 and your iTunes tells you there is an update and it's 1.1.4, can you simply take that leap from 1.1.2 to 1.1.4? Or, do you have to first download the 1.1.3 and do the shift+update, then update to 1.1.4?
No jailbreaking intended with this update.
Thanks.
bean22
Dec 13, 2007
65
If you're not jailbroken, then you should be able to upgrade straight to 1.1.4. I'm assuming iTunes will update your phone to 1.1.3 first, then to 1.1.4 all in the same process.
