When I plug my headphones in it doesn't work!
ekologik
Feb 25, 2008
I don't' know what to do... I have 2 different headsets and when I plug each of them in, it doesn't work. Like, the phone doesn't "register" that there's anything plugged in.
What can I do? I want to be able to listen to my music with headphones. Thanks!
Jul 16, 2008
1,592
Colorado
Did this just start happening or have you been able to use your headphones before? If they have worked before just restart the phone and see if it works.
ekologik
Feb 25, 2008
hey there, thanks. i came across a website that told me to do that and that suggestion works. i'm so glad! thanks for your reply!
just for googling sake, if someone finds this post with the same prob, you can restart your iPhone by holding down the home and power buttons until the Apple logo appears (holding it after it says "slide to power off").
thanks again!
chrismmm
Dec 27, 2007
612
Gwinnett, Georgia
when this happens again..just reboot.it is the common cure for a lot of iPhone and application issues
