Where are all my pdf's in iBooks?
EverythingApple
Jul 28, 2010
3,862
225
North Jersey
Opened up iBooks for the first time on my iPhone 6 and all my saved pdf's are gone. They were there on my 5. And saved in iCloud. What now?
28,365
5,506
Did you switch to PDF view?
28,365
5,506
I tried that. They're not there. :(
Open the iBooks app on your Mac and go to Collections and then PDFs. Are they listed there?
If they are there but not on your phone, do you have iCloud Drive toggled on in the iCloud settings on your phone?
EverythingApple
Jul 28, 2010
3,862
225
North Jersey
I don't have iCloud Drive activated.
28,365
5,506
You didn't answer my first question, but going with your partial reply, I think that's the problem. It's on on your Mac, but not your phone. It has to be the same service to sync them to your phone. Check if it's on in iCloud in the Settings app on your Mac. You'll need to change from Documents and Data to iCloud Drive if you want to sync that stuff
NickB
Nov 28, 2007
89
My ibooks hasn't been syncing books (pdf's) across my devices either, and I just checked in iCloud settings on my mac and iPhone 6 and don't see ibooks anywhere in there. And iCloud drive is turned on. any ideas?
28,365
5,506
Is iCloud Drive enabled on the iPad/iPhone?
NickB
Nov 28, 2007
89
Yeah, it says "on" in settings for iCloud. I assume its on on the mac because I see an iCloud drive section in Finder
EverythingApple
Jul 28, 2010
3,862
225
North Jersey
The MacBook I used to backup/restore my iPhone is a mid-2007. It doesn't have iBooks on it. Unless it's in iTunes. I can check the iCloud.
28,365
5,506
Open the iBooks app on your Mac and go to Collections and then PDFs. Are they listed there? If not, go to File > Move Books from iTunes.
It's no longer included in iTunes. They made it a stand-alone app with Mavericks. iBooks requires Mavericks. Since your computer is too old to run Mavericks, you may not be able to sync .PDFs through iCloud anymore. You can still recover them, though. Are your .PDFs listed here? Can you select them to sync them though iTunes?
If they aren't listed there, use Finder to recover them. Go to the Books folder here:
Finder > Go to Folder > ~/library > Containers > com.apple.BKAgentservice > Data > Documents > iBooks > Books. You can drag the .PDFs to your desktop from there.
EverythingApple
Jul 28, 2010
3,862
225
North Jersey
Some are there, but not the most recent ones that I'm looking for. It's not that important. I presume the iBooks folder on my iPhone, is where I should look where you mention going to finder above??
NickB
Nov 28, 2007
89
Europa, my problem is a little different than EverythingApple's, I have all my pdfs in ibooks on all my devices (not missing like he states). Some I had put in ibooks on the mac, some on the iPhone, but i synced the devices collections through iTunes. The problem I have is that a pdf put into iBooks on my iPhone would not show up automatically on the mac or my iPad unless I synced through iTunes. The weird thing is, If I read one on any device and then later open that pdf on another device, it does go to the page I left off on from the first device, so it seems like its partially syncing?
I just thought the problems may be related so I posted here.
28,365
5,506
No, I posted the file location on a Mac. Let me know if they are there.
28,365
5,506
You have to put them on the computer first if you want them to sync to all of your other devices. Once they are on all devices, the page location, highlights, etc. will sync across devices through iCloud.
EverythingApple
Jul 28, 2010
3,862
225
North Jersey
Says no folder exists.
NickB
Nov 28, 2007
89
So a PDF added to ibooks on the mac should show up on iPhone and iPad via cloud, but added on the mobile devices won't show up on the mac then?
