Where are videos located on your PC
Stoldit
Aug 17, 2007
46
I was using another computer due to no Vista support 64 bit, now I am using my 64 bit system.
However, the shows and music I bought on my other computer are not visible here.
How do I get that stuff that i bought on the other computer onto this 64 bit system.
15,385
1,089
move onto a portable storage device (flash drive, external hard disk, cds, dvds, etc), and add the files to the new PC's iTunes. all of your stuff should be in your C:\username\My Documents\Music\iTunes\iTunes Music... unless you put them somewhere else.
You will then have to "authorize" the computer to play the purchased content. If you are not going to be using the old computer anymore, you should "deauthorize" it. This is because you can have only 5 computers at a time authorized to play the content, so if you get rid of an authorized computer, you might run into problems authorizing future computers.
KNK
Jul 22, 2007
2,391
Stevenson Ranch
Also everyone should know the 1.1.3 update took care of the Vista Problems.
