Where can I get cheap chargers?
stevensondrive
Jun 11, 2009
47
The ones I got from eBay are horrible to remove. So I need a little help. I am looking at $40 at walmart
Marianne
2,326
29
Massachusetts
marianneschultz.com
No worries - I moved it to the correct forum.
I wouldn't suggest you try to find a cheap charger, actually. I have read stories of cheap chargers frying iPhones, so I think it's prudent to not skimp on getting one made by a reputable manufacturer or from Apple directly. Griffin makes good chargers if you want to go aftermarket. Or perhaps eBay auctions for used OEM Apple chargers?
IBJanky
Jun 12, 2009
37
Long Beach, CA
I get all my chargers from eBay and never had a problem with any of them.
myke
Jun 24, 2009
i lost my original charger and bought a new usb charger from a site called inspiretech.com i also need to pick up a car charger from them to but im broke but next paycheck, hope this helps some one out... link
LB56
Jun 18, 2009
Jun 30, 2009
231
I bought last time my charger from eBay and their prices was quite reasonable to me. You may find chargers in some other places but I suggest eBay will be an easier technique.
