Where do I get NES emulator?
jerrettpaul
110
Denton, TX
its not on AppTapp installer. where do i find it? and how do i put it on the installer?
jerrettpaul
110
Denton, TX
yeah i have the apptapp installer widget. right now im getting BSD subsystem, im not sure what it does but i guess i'll find out. anyways all i see is the doom app. i cant download i brickr, because i have iTunes 7.4
x999x
Aug 6, 2007
1,656
From Installer look for the Community Sources and install it. It adds more applications to your Installer application listing.
wildonrio
Jul 4, 2007
2,002
Provo, UT
Ok, I think you're confused (or I am). AppTap is a Windows/Mac software. The "Installer" widget is software for your phone and you use AppTap to get the Installer widget on your phone. So just to clarify, AppTap and the Installer widget are two separate things.
As far as your issue, if you click on the Installer widget on your homescreen, you should see a list of programs to download straight to your phone. If you don't see the NES program, have you tried first installed the Community Sources? Once you do this, a lot more programs appear in Installer.
I hope this helps. If it doesn't, then go to http://iPhone.natetrue.com/nesapp/ and download the NES application yourself. Then download WinSCP, connect to your iPhone using user:root pw:dottie and then browse to your Applications folder. Now transfer the NES.app folder (that you downloaded) into the Applications folder on your phone. Now restart your phone and you should see it on your homescreen as a widget. (To get roms on there, use WinSCP again and put your rom files (*.nes) into var/root/Media/ROMs/NES
