Where do I get summerboard from?
H
Hayesimus
Guest
it should be in there. Did you select all packages? or recent packages? also you may have to add sources.I'm not sure which source it is. But just go into installer. tap sources in the bottom right hand corner and then tap Edit in the top right hand corner and then add whichever source you are wanting to add. you can do a search on this forum and find "all sources" that should get you going.
themanofthedark
Jan 5, 2008
2,674
Boston
its the Ste source, i do believe.
go All Packages --> Community Sources
then go System --> Summerboard
good day.
