Where do I get transparent icons?
Rockky
Aug 8, 2007
333
Not the labels...the icons...can't find them on cydia, don't have Installer
iErik
Oct 27, 2007
1,221
72
Las Vegas, NV
Just put the icons in whatever theme you want.
OJsakila
Jul 15, 2007
3,021
Jupiter's sulphur mines
install all sources via cydia. They're called "blank apps". They're there because I use them. You can install up to twenty at a time or individually
Jul 6, 2007
1,832
26
Marietta, GA
about.me
You can also use plainjaindim from cydia. its in the themes (springboard) section. I think you might have to use winterboard for it.
HBOC
Aug 4, 2008
108
Portland, Oregon
if you have adobe fireworks CS3, you can open the .png files via ssh of the icons you want and then change the opacity of them, making them transparent. i do this and works great!
aaronsiphone
Dec 28, 2007
297
Have you got the exact source for the blank app because im not going through this whole all sources thing again, it does my head in
iErik
Oct 27, 2007
1,221
72
Las Vegas, NV
Blank apps come from Steffwiz's source.
psylichon
Oct 31, 2007
16,591
751
41
Philly
That source doesn't work anymore.
aaronsiphone
Dec 28, 2007
297
hanks for that, does this source have any other good apps on?
aaronsiphone
Dec 28, 2007
297
Sorry, poor english, i meant how do you install more than one of these blank apps, i.e 2 or more
Saverino
Jun 1, 2008
4,480
92
Burbank
Is the Gruppled theme's background supposed to change to different things? And if it is...when do they change?
SikShift
Jul 22, 2008
1,739
Bradenton, FL
I'd like to know this too. I installed the blank app, but I don't know how to install more
I think I read somewhere that it comes with four different backgrounds, but i didn't know that they changed by themselves. Which also means i don't know when they change :p
