Where is Gmail app in iFile?
Kadelic
Jan 4, 2010
4,935
1,645
Dallas, TX
Ugh. That's a lot to remember. I can't find
that one. Mines a different set of numbers/letters. And it's for the GmailHybridApp.
I'm betting that's exactly where you'll find the icon you want to theme. Make sure you have Appication Names toggled on in iFile settings. GmailHybridapp is inside the Gmail folder at the path Naps posted. Within that "Hybrid" folder are several .png files. You just have to replace the one that corresponds to your specific device.
Apologies in advance if I've misunderstood and am stating the obvious. :)
EverythingApple
Jul 28, 2010
3,862
225
North Jersey
Thanks, I didn't know that. I just toggled them on. But which icon is for iPhome 6?
28,365
5,506
I tried it and it didn't work. I tried a more simpler app, TD Bank, and it didn't work. Do I need to resize the pic I save to be copied to the correct location? I'm obviously doing something wrong.
I did it the same way @MoneyMaker79 did and themed all of the icons in the mail folder. Here's an example with the stock mail app. I just switched it to an alternate and it applied after a respring, but I changed all of these files. They can all be the same file/same size.
