Where to copy ringtones to?
Ibrahim Allaf
Apr 28, 2011
102
Dubai, U.A.E.
berryracer.com
I've synced all my MP3s from my PC to my iPhone 5.
Now where and how do I copy my ringtones to my iPhone? My ringtones are all in MP3 format but I don't want them to go to my Music library as these are only ringtones...
please advice
thanks
Docd
Oct 16, 2011
651
62
They will need to be converted from mp3 to m4r format for them to work and show up on iTunes.
  • Like
Reactions: Ibrahim Allaf
RoofMonkey
Jun 21, 2010
8,921
1,983
A program that I use to easily convert any part of an mp3 fle to Apples format is iRinger. Easy 3 step process and will sync directly to the appropriate area of iTunes for you too.
www.iRinger.net it's even free
Sent using iCafe app
  • Like
Ibrahim Allaf
Apr 28, 2011
102
Dubai, U.A.E.
berryracer.com
oh thanks ill try it when I get home.
But after I convert them to the mr4 format, how to copy those ringtones to my phone? I hope the phone won't confuse them and the regular songs (MP3s) in the Music library
RoofMonkey
Jun 21, 2010
8,921
1,983
No you should be able to just drag the m4r files into iTunes and it should see them as ringtones. You can do this all from iTunes if you want. Here's a guide. http://howto-themes-for-iphones.blogspot.com/2009/12/how-to-convert-mp3-to-m4r.html?m=1
That does work, but what a royal pain. The iRinger program I mentioned will do all of this in 3 steps. Of course the first and hardest step is selecting which part of that mp3 you want as a ring tone, since you are limited to a max of 29 seconds for a ringtone.
Docd
Oct 16, 2011
651
62
Well the op already has the ringtones just in the wrong format. If its just one or two I would just use iTunes to convert instead of installing a program but if is a bunch the a program is the way to go. I don't do it enough to waste space on my Mac.
  • Like
RoofMonkey
Jun 21, 2010
8,921
1,983
Point noted... And a good one at that ;)
Ibrahim Allaf
Apr 28, 2011
102
Dubai, U.A.E.
berryracer.com
Well the op already has the ring tones just in the wrong format. If its just one or two I would just use iTunes to convert instead of installing a program but if is a bunch the a program is the way to go. I don't do it enough to waste space on my Mac.
You're right bro, I have all my ring tones I create them myself using Adobe Audition, then increase their amptitude (volume) using Adobe Audition, cut them, and I'm all set with loud and clear custom ring tones from the best parts of the songs that I want
I'll post my collection soon
enjoylife1788
Jan 7, 2011
186
Look forward to your collection :)
