Which apps are gobbling up your data plan?
ZR_Yancy
Jul 11, 2008
3,982
737
Just found a new and free app the will track your data usage. It will also break down how much data each app is using. It's called Onavo Count. Grab it before they put a price on it.
5,580
Just installed it. I imagine it will be pulled from the App Store soon or at least disabled by 6.0.1 since it installs a profile and requires your lock screen passcode (if you have one set). We had some pretty awesome settings toggles on 5.0, which also installed a profile and were a great SBSettings alternative since the 4S jailbreak wasn't out yet, but Apple quickly disabled them with a firmware update.
mrbunglez
Mar 20, 2008
439
100
43
Downloaded that app awhile was good until it didn't let me load up a few of my apps, namely the FB app.
ZR_Yancy
Jul 11, 2008
3,982
737
I can't imagine how Apple would have missed its function since it asks to installed a profile as soon as it is initially launched.
ZR_Yancy
Jul 11, 2008
3,982
737
I didn't have any problems with FB after I installed Onavo. What OS were you on? Are you Jailbroken?
mrbunglez
Mar 20, 2008
439
100
43
No jail break and it was awhile ago so prob an old OS 5.1? Not sure. Guess they fixed it.
5,580
Do you know if there are any other apps out there that require installing these profiles? It was just a guess based on Apple disabling the 5.0 settings toggles that used these profiles.
Iloveiphones
Aug 5, 2010
6,237
234
chatsocially.com
The data compressing app, Snappli.
5,580
Thanks. Apparently, it wasn't the profile installation that caused Apple to disable the toggles then.
