Which case is better?
GrannySmith
Jun 4, 2012
20
I can't decide between the "Speck Candyshell satin" case or the "Puregear Dualtek Extreme Shock Case". Both look awesome but I like the speck's look a lot more than puregear's.
Problem is, I've been getting mixed reports about the candyshell cases. The regular candyshell apparently shows scratches a lot on the glossy finish while the satin ones i've had mixed opinions. Some people say that the matte finish coating comes off in a few weeks.
As for puregear, it seems to have better quality and protection but the look of the case isn't as great as speck's. Has anyone had a speck candyshell satin before? Any problems with the coating rubbing off after time? Is it durable at all? All these things I've been hearing about speck make the case look kind of cheap :/
Kgd0630
Aug 8, 2010
330
33
Anderson, SC
I've had a few candyshells, and so has a close friend. They scratch BADLY! But look and feel great for about 6 months total.
Sent using iCafe app
flatbacks21
Sep 21, 2010
342
9
Ohio
I use the speck candyshell and yes, it gets scuffed up. My thought is I'd rather the case get scuffed up than the phone. In my opinion it's doing the job. Plus it does a pretty good job of protecting the phone when dropped. That's just me. Purchased on amazon for $20.
missygal
Jul 2, 2010
599
133
43
I also had the Candyshell...mine has some scratches but I like the feel of the case so I can handle some scratches.
Sent using my iPhone 5
mistah_mumford
Dec 30, 2012
SC
I like the Candyshell as well. I took one of those kitchen sponge/scrub pads to the back to remove the shine and DRASTICALLY reduce the appearance of scratches!
Sent from my iPad 2 using Tapatalk
